Adjusting Line Lengths
Go to solution Solved by Chopsaw,
Hello,
This seems like it should be really simple, and that I must be doing something wrong, but I can't find an answer. When I am drawing a CAD line, how can I easily adjust the length? I know that I can open the object properties, but doing this requires more work than it should. In other CAD programs I have used, you simply start drawing the line and then type in the length you want, is there anything similar in Chief, or is it only by opening the object properties?
Thank you,
  • Solution
Just one extra key stroke.  Start drawing and then hit tab to enter the length.
    29632
    seanf123
    seanf123
