J_Mack Posted June 2, 2021 Share Posted June 2, 2021 Any suggestions about how I could create these stairs in Chief? I think I'm close to figuring it out with the exception of how to do the opening under the hand rail and then also the metal rail directly under the handrail. Thanks! Chief Architect Premier X12 Build 22.3.0.55X65 Link to comment Share on other sites More sharing options...
rgardner Posted June 2, 2021 Share Posted June 2, 2021 You will need to create a custom stair rail panel and use it. Link to comment Share on other sites More sharing options...
Mark3D Posted June 2, 2021 Share Posted June 2, 2021 Would that be close enough if so it is just using railing panel from core catalog and the hand rail can be set to what ever you want Link to comment Share on other sites More sharing options...
J_Mack Posted June 7, 2021 Author Share Posted June 7, 2021 The tri-section worked great! Thank you!!!!! I wasn't able to apply it successfully from the interior staircase specification box like you show. I searched and found the tri-section in my library browser and "spray painted" it onto my balusters in 3D. Link to comment Share on other sites More sharing options...
