builtright3 Posted May 21, 2021 Share Posted May 21, 2021 How do I change the direction of plank flooring if I'm putting it on a wall? Right now it is vertical and I want it to be horizontal. Any help would be appreciated Link to comment Share on other sites More sharing options...
joey_martin Posted May 21, 2021 Share Posted May 21, 2021 Make a copy of the material, rotate it 90d. Link to comment Share on other sites More sharing options...
builtright3 Posted May 21, 2021 Author Share Posted May 21, 2021 8 minutes ago, joey_martin said: Make a copy of the material, rotate it 90d. I used the material region to put it on the wall and tried to rotate it 90d but that didn't work. Not sure if that is what you meant. What do you mean make a copy of the material? Link to comment Share on other sites More sharing options...
joey_martin Posted May 21, 2021 Share Posted May 21, 2021 No. Open the actual material and make a copy. Name it and rotate it. With the material region you are rotating the "region" not the material. Link to comment Share on other sites More sharing options...
builtright3 Posted May 21, 2021 Author Share Posted May 21, 2021 46 minutes ago, joey_martin said: No. Open the actual material and make a copy. Name it and rotate it. With the material region you are rotating the "region" not the material. Thank You! Link to comment Share on other sites More sharing options...
