How do I change the direction of plank flooring if I'm putting it on a wall? Right now it is vertical and I want it to be horizontal.
Any help would be appreciated
8 minutes ago, joey_martin said:
Make a copy of the material, rotate it 90d.
I used the material region to put it on the wall and tried to rotate it 90d but that didn't work. Not sure if that is what you meant. What do you mean make a copy of the material?
No. Open the actual material and make a copy. Name it and rotate it. With the material region you are rotating the "region" not the material.
Thank You!
    29633
    prologuy
    prologuy
