RobUSMC Posted April 9, 2021 Share Posted April 9, 2021 Is it possible to create a 3D tile like I've got attached in Substance Player? If not, does anyone know where I could find a seamless tile texture showing lite / white grout lines? Link to comment Share on other sites More sharing options...
robdyck Posted April 9, 2021 Share Posted April 9, 2021 Daltile has one that's pretty close. A little low res though. Search the library for Snow Waves Deco J400 Link to comment Share on other sites More sharing options...
RobUSMC Posted April 9, 2021 Author Share Posted April 9, 2021 Thanks. Im needed something a bit more 3D Link to comment Share on other sites More sharing options...
robdyck Posted April 9, 2021 Share Posted April 9, 2021 On 4/9/2021 at 2:17 PM, RobUSMC said: Thanks. Im needed something a bit more 3D Expand Maybe this would be a good starting point. You can always try copying a 24x12 tile normal map for grout joints. Link to comment Share on other sites More sharing options...
Chief_Content Posted April 20, 2021 Share Posted April 20, 2021 Hi RobUSMC, "3D Wall White Matte Ribbon" should work well for you. It uses a normal map which gives it the 3D look you're after. You can find it here: Cactus Stone Tile Ceramic 3D Wall 3D Wall White Matte Ribbon I hope this material provides a good solution for your needs. 2 Link to comment Share on other sites More sharing options...
RobUSMC Posted April 20, 2021 Author Share Posted April 20, 2021 Thanks Link to comment Share on other sites More sharing options...
