MAP6933 Posted April 4, 2021 Share Posted April 4, 2021 Two different sets of labels are populating on my wall elevation view. When I'm in plan view everything looks normal, only one set populates. Link to comment Share on other sites More sharing options...
MarkMc Posted April 4, 2021 Share Posted April 4, 2021 Check project browser to see if there are two schedules which is most likely issue. There could be two sets of labels in plan view just on top of each other. OR there are two cabinets. I had an assistant who would often accidentally copy and paste in place. Link to comment Share on other sites More sharing options...
Dermot Posted April 5, 2021 Share Posted April 5, 2021 99% of the time this is because these cabinets are listed in two different schedules. To figure out which schedules, just open your Project Browser and look in the Schedules section (not the CAD Details section). You can delete your schedules one at a time to see which ones are generating the callout labels. If this does not solve your problem, then you may want to either post your plan or contact tech support. Link to comment Share on other sites More sharing options...
