Saltydogprop Posted March 23, 2021 Share Posted March 23, 2021 Exterior Dimensions are are snapping to the siding layer, how do you change to it snap to the sheathing so the dimensions match the foundation. Link to comment Share on other sites More sharing options...
GeneDavis Posted March 23, 2021 Share Posted March 23, 2021 Look carefully at your wall definition panel. Use the help function if needed, the button at bottom when the spec dialog is open. Link to comment Share on other sites More sharing options...
ericepv Posted March 23, 2021 Share Posted March 23, 2021 You should be able to set this in your defaults - Edit/Default Settings/Dimension Link to comment Share on other sites More sharing options...
