winterdd Posted March 20, 2021 Share Posted March 20, 2021 I forget how to set it up to where the exterior side of the stud wall is in line with the exterior side of the running block. (bumped outward) Link to comment Share on other sites More sharing options...
winterdd Posted March 20, 2021 Author Share Posted March 20, 2021 exactly like this....... Link to comment Share on other sites More sharing options...
Ridge_Runner Posted March 20, 2021 Share Posted March 20, 2021 I set my exterior foundation block wall to the 1st item in the main layer to match the stud wall above. Set the foundation wall type to the same "Foundation to Exterior Layer" to match. Link to comment Share on other sites More sharing options...
winterdd Posted March 20, 2021 Author Share Posted March 20, 2021 cool, thanks! how do you set up a horizontal brick wall cap to close off the foundation at the top? just seeing if your way is easier. Link to comment Share on other sites More sharing options...
Ridge_Runner Posted March 20, 2021 Share Posted March 20, 2021 I find it is easier to click just outside the exterior of the house and go to the edit toolbar and make a molding polyline for the exterior. I have a molding I made and put in my library of the cross section of the sloped brick sill I use. Apply it to the molding line and it works well for me. Adjust the offset in the molding panel until you get it where you want it vertically. Applying the brick material to it usually works OK. 1 Link to comment Share on other sites More sharing options...
winterdd Posted March 20, 2021 Author Share Posted March 20, 2021 the problem was on the foundation wall type. i had the air gap and brick on the main layer not exterior. Link to comment Share on other sites More sharing options...
Ridge_Runner Posted March 20, 2021 Share Posted March 20, 2021 You will have to "fiddle" with some breaks in the molding line in plan view to remove any area you don't want the sill; like porches. Break the line, click on the section you don't want the sill on, and in the far right of the edit toolbar will be a molding shape with an "X" thru it. Click that button and it will remove the molding on that section. 1 Link to comment Share on other sites More sharing options...
winterdd Posted March 20, 2021 Author Share Posted March 20, 2021 thanks ridge! Link to comment Share on other sites More sharing options...
rgardner Posted March 20, 2021 Share Posted March 20, 2021 Another way of doing it and it is limited to only two pony walls at this time is to use a brick 6 pony wall to 1.5" high and then siding 6 above it (for example) with a molding applied at the wall. For other situations where you need another pony wall there you will have to use Mike's suggestion. The key to it lining up though is yoru wall definition. Build the walls JUST like they would IRL in order for them to line up. 1 Link to comment Share on other sites More sharing options...
winterdd Posted March 20, 2021 Author Share Posted March 20, 2021 7 hours ago, rgardner said: Another way of doing it and it is limited to only two pony walls at this time is to use a brick 6 pony wall to 1.5" high and then siding 6 above it (for example) with a molding applied at the wall. For other situations where you need another pony wall there you will have to use Mike's suggestion. The key to it lining up though is yoru wall definition. Build the walls JUST like they would IRL in order for them to line up. very true!! this worked. Link to comment Share on other sites More sharing options...
