Chopsaw Posted March 7, 2021 Share Posted March 7, 2021 Is there any way to prevent siding from wrapping into a frameless opening of a pass-through ? It would be great if the house wrap did this when you wanted it to but not the siding.... Link to comment Share on other sites More sharing options...
Chopsaw Posted March 7, 2021 Author Share Posted March 7, 2021 Just now, solver said: Use the frame. Apply house wrap to the frame ? Ingenious How about a pass-through vent with no frame, no house wrap and no "siding wrap" ? Link to comment Share on other sites More sharing options...
Alaskan_Son Posted March 7, 2021 Share Posted March 7, 2021 4 minutes ago, Chopsaw said: Apply house wrap to the frame ? Ingenious How about a pass-through vent with no frame, no house wrap and no "siding wrap" ? Old fashion material regions and manually editing framing or Symbol set to Inserts Into Wall along with its Wall Cutout Polyline. Link to comment Share on other sites More sharing options...
Chopsaw Posted March 7, 2021 Author Share Posted March 7, 2021 Just now, Alaskan_Son said: Symbol set to Inserts Into Wall along with its Wall Cutout Polyline. I tried that on an attic wall on the same project and it was a disaster but this wall is balloon framed so it might work. Thanks. Otherwise yes for material regions. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted March 7, 2021 Share Posted March 7, 2021 20 minutes ago, Chopsaw said: ....it was a disaster.... Hyperbolize much? If only all disasters could be addressed by simply hitting the delete key Link to comment Share on other sites More sharing options...
Chopsaw Posted March 7, 2021 Author Share Posted March 7, 2021 2 minutes ago, Alaskan_Son said: If only all disasters could be addressed by simply hitting the delete key If only the delete key could return all the time that was wasted I would be just fine. Link to comment Share on other sites More sharing options...
Chopsaw Posted March 7, 2021 Author Share Posted March 7, 2021 2 hours ago, solver said: Thank You Eric !! There is no way I would have believed that if you told me. I had to watch it 5 times... Make a setting for a completely different type of window that happens to use the same DBX for an item that has no relation to what you would expect to fix a problem that should not exist. WOW !! That makes for a $200.00 window opening that no one will ever see. Link to comment Share on other sites More sharing options...
