Chopsaw 681 Posted March 7 Is there any way to prevent siding from wrapping into a frameless opening of a pass-through ? It would be great if the house wrap did this when you wanted it to but not the siding.... Share this post Link to post Share on other sites
Chopsaw 681 Posted March 7 Just now, solver said: Use the frame. Apply house wrap to the frame ? Ingenious How about a pass-through vent with no frame, no house wrap and no "siding wrap" ? Share this post Link to post Share on other sites
Alaskan_Son 2602 Posted March 7 4 minutes ago, Chopsaw said: Apply house wrap to the frame ? Ingenious How about a pass-through vent with no frame, no house wrap and no "siding wrap" ? Old fashion material regions and manually editing framing or Symbol set to Inserts Into Wall along with its Wall Cutout Polyline. Share this post Link to post Share on other sites
Chopsaw 681 Posted March 7 Just now, Alaskan_Son said: Symbol set to Inserts Into Wall along with its Wall Cutout Polyline. I tried that on an attic wall on the same project and it was a disaster but this wall is balloon framed so it might work. Thanks. Otherwise yes for material regions. Share this post Link to post Share on other sites
Alaskan_Son 2602 Posted March 7 20 minutes ago, Chopsaw said: ....it was a disaster.... Hyperbolize much? If only all disasters could be addressed by simply hitting the delete key Share this post Link to post Share on other sites
Chopsaw 681 Posted March 7 2 minutes ago, Alaskan_Son said: If only all disasters could be addressed by simply hitting the delete key If only the delete key could return all the time that was wasted I would be just fine. Share this post Link to post Share on other sites
Chopsaw 681 Posted March 7 2 hours ago, solver said: Thank You Eric !! There is no way I would have believed that if you told me. I had to watch it 5 times... Make a setting for a completely different type of window that happens to use the same DBX for an item that has no relation to what you would expect to fix a problem that should not exist. WOW !! That makes for a $200.00 window opening that no one will ever see. Share this post Link to post Share on other sites
