Siding Wrap
Chopsaw
4 minutes ago, Chopsaw said:
Apply house wrap to the frame ?   Ingenious
How about a pass-through vent with no frame, no house wrap and no "siding wrap" ?
Old fashion material regions and manually editing framing or Symbol set to Inserts Into Wall along with its Wall Cutout Polyline.
I tried that on an attic wall on the same project and it was a disaster but this wall is balloon framed so it might work.  Thanks.
Otherwise yes for material regions. :D
2 minutes ago, Alaskan_Son said:
If only all disasters could be addressed by simply hitting the delete key :)
If only the delete key could return all the time that was wasted I would be just fine.
2 hours ago, solver said:
Thank You Eric !!   There is no way I would have believed that if you told me.  I had to watch it 5 times...
Make a setting for a completely different type of window that happens to use the same DBX for an item that has no relation to what you would expect to fix a problem that should not exist.   WOW !!
That makes for a $200.00 window opening that no one will ever see. ;)
