Nicu101268 Posted February 27, 2021 Share Posted February 27, 2021 Is there any possibility to fill the corner B in the same way as the one in A when we create entrance stairs? Link to comment Share on other sites More sharing options...
Nicu101268 Posted February 27, 2021 Author Share Posted February 27, 2021 Thanks @solver, but I don't understand. Can you provide an example? I know how to make stairs with two sections or more and I know about landings but in that case does not works because the stairs are the same slope in the same sense. Link to comment Share on other sites More sharing options...
Nicu101268 Posted February 28, 2021 Author Share Posted February 28, 2021 Yes, I upgraded to v11. From the videos I've seen it looks like the corners of the stairs is joined only for decks and porchs. Link to comment Share on other sites More sharing options...
Nicu101268 Posted February 28, 2021 Author Share Posted February 28, 2021 In that case does not work. Maybe I don't know how to work correctly with the program. Link to comment Share on other sites More sharing options...
DavidJPotter Posted February 28, 2021 Share Posted February 28, 2021 The difference is that Eric placed the edge of this stair object precisely at the corners, you did not. Stair objects are preprogrammed to snap together at their corners provided you place them there with precision. DJP Link to comment Share on other sites More sharing options...
Nicu101268 Posted February 28, 2021 Author Share Posted February 28, 2021 Thanks for your supports. I made some tests. In the left side of image even does not work but in the right side I made a test and it works. I don't know what to say ... I check my plan again. LE: When I built the foundation the stairs is disconnected. Link to comment Share on other sites More sharing options...
Nicu101268 Posted February 28, 2021 Author Share Posted February 28, 2021 The stairs corner is disconnected only if I built Monolithic Slab foundation. I don't know why. Link to comment Share on other sites More sharing options...
Nicu101268 Posted February 28, 2021 Author Share Posted February 28, 2021 Thanks again @solver. You have a lot of patience with me. Surprisingly, if I apply the stairs to the foundation floor, everything is OK, but it does not appear in the plan on the 1st floor. In 3D View everything is OK. I think I'll leave it at that. Thanks. Link to comment Share on other sites More sharing options...
