Sign in to follow this
Nicu101268
Stairs corner
Is there any possibility to fill the corner B in the same way as the one in A when we create entrance stairs?
Thanks @solver, but I don't understand. Can you provide an example?
I know how to make stairs with two sections or more and I know about landings but in that case does not works because the stairs are the same slope in the same sense.
Yes, I upgraded to v11.
From the videos I've seen it looks like the corners of the stairs is joined only for decks and porchs.
In that case does not work. Maybe I don't know how to work correctly with the program.
The difference is that Eric placed the edge of this stair object precisely at the corners, you did not. Stair objects are preprogrammed to snap together at their corners provided you place them there with precision.
Thanks for your supports. I made some tests. In the left side of image even does not work but in the right side I made a test and it works.
I don't know what to say ... I check my plan again.
LE: When I built the foundation the stairs is disconnected.
The stairs corner is disconnected only if I built Monolithic Slab foundation. I don't know why.
Thanks again @solver. You have a lot of patience with me.
Surprisingly, if I apply the stairs to the foundation floor, everything is OK, but it does not appear in the plan on the 1st floor.
In 3D View everything is OK. I think I'll leave it at that. Thanks.
    29351
    LawrenceG
    LawrenceG
