Steve-C Posted February 26, 2021 Share Posted February 26, 2021 I know I've dealt with this topic in the past but I can't seem to find the answer in a search. When creating an arched molding, I thought there used to be an option to adjust the minimum degree of the arch in the dbx but I can't seem to find it now. So instead of a smooth radius it's more like a series of straight lines in the shape of an arch. Is there an adjustment I'm missing somewhere? Link to comment Share on other sites More sharing options...
glennw Posted February 26, 2021 Share Posted February 26, 2021 Polyline Specification dbx>Selected Arc panel>Arc>uncheck Automatic Facet Angle>Facet Angle. The lower the value, the smoother the curve. Link to comment Share on other sites More sharing options...
Steve-C Posted February 26, 2021 Author Share Posted February 26, 2021 17 minutes ago, glennw said: Polyline Specification dbx>Selected Arc panel>Arc>uncheck Automatic Facet Angle>Facet Angle. The lower the value, the smoother the curve. It's not a polyline solid it's a molding polyline. Link to comment Share on other sites More sharing options...
justmejerry Posted February 26, 2021 Share Posted February 26, 2021 If you draw a plain polyline instead of 3d moulding line you can add the curve and then change it with convert curve to polyline and increase segments which will smooth the curve. Link to comment Share on other sites More sharing options...
