JPAK2021 Posted February 19, 2021 Share Posted February 19, 2021 Hi all. I'm using Premier X12 Student Edition. So I'm trying to raise the ceiling in my first level. As you you can see, the garage is basically sitting on the roof. Any idea why new walls are being created when trying to expand the ceilings to 9' on the first level? Link to comment Share on other sites More sharing options...
rgardner Posted February 19, 2021 Share Posted February 19, 2021 Turn auto rebuild roofs back on. 1 Link to comment Share on other sites More sharing options...
JPAK2021 Posted February 20, 2021 Author Share Posted February 20, 2021 Thanks, that did it. Link to comment Share on other sites More sharing options...
mtldesigns Posted February 20, 2021 Share Posted February 20, 2021 2 hours ago, JPAK2021 said: ceilings to 9' on the first level Hey JP, Get used to using pre cut lumber lengths for your walls too. I don't know if this is actual assignment, if so, your tech professor will explain. In essence for a 9' ceiling, your rough needs to be 109 1/8". The finish ceiling will be be based on your ceiling drywall thickness, if strapping is needed (typical in the NE), and your floor finish. Study up on this, you might impress your instructor then. https://www.ezwoodshop.com/blog/lumber/lumber-dimensions-weird-2x4-lengths/ https://www.homeconstructionimprovement.com/why-use-pre-cut-studs-for-framing-walls/ teaching a man to fish.... 1 Link to comment Share on other sites More sharing options...
