BruceKC Posted February 9, 2021 Share Posted February 9, 2021 I have added a column on the front porch. Is there a way to make the column symbol have a fill pattern in plan view? Link to comment Share on other sites More sharing options...
Chopsaw Posted February 9, 2021 Share Posted February 9, 2021 Technically no but there are a few ways you could get around this. Place a polyline with fill over your displayed symbol, or create a cad block with lines and assign that to replace the 2D block that the symbol uses. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted February 9, 2021 Share Posted February 9, 2021 You can also create an Architectural Block using a closed molding polyline (no molding assigned) to supply the desired fill. Then you can add to/pull from library and copy/paste elsewhere as a single object. Link to comment Share on other sites More sharing options...
BruceKC Posted February 9, 2021 Author Share Posted February 9, 2021 Thanks everyone. Seems a bit strange that a column on the front porch would have no fill, but it's not a big deal I guess. thanks again! Link to comment Share on other sites More sharing options...
Alaskan_Son Posted February 9, 2021 Share Posted February 9, 2021 4 minutes ago, BruceKC said: Thanks everyone. Seems a bit strange that a column on the front porch would have no fill, but it's not a big deal I guess. thanks again! It can have a Fill using Open Symbol>2D Block. You just can’t get a PATTERN that way. Link to comment Share on other sites More sharing options...
