mtldesigns Posted February 3, 2021 Share Posted February 3, 2021 Curious as of late.. but it seems that IN THE PAST when moving a wall via a dimension, that most of the time any connected wall moved as well.. esp. exterior walls. Why doesn't it do this any more? Link to comment Share on other sites More sharing options...
mtldesigns Posted February 3, 2021 Author Share Posted February 3, 2021 sorry, not yelling in subject.. forgot to turn off caps Link to comment Share on other sites More sharing options...
Alaskan_Son Posted February 3, 2021 Share Posted February 3, 2021 It’s always about WHICH wall you select and which of the associated dimensions you click on. you can either select the wall and then click on a parallel dimension in which case you will be changing its length or you can click on a perpendicular dimension in which case you would be MOVING the wall along with any connected walls ends. Link to comment Share on other sites More sharing options...
mtldesigns Posted February 3, 2021 Author Share Posted February 3, 2021 52 minutes ago, Alaskan_Son said: or you can click on a perpendicular dimension in which case you would be MOVING the wall along with any connected walls ends. that's what I thought also, but just like the example, I picked the ext. and railing wall, and picked the dim that was perp to it.. both of the walls moved, but the ext. and rail wall that was perp/connected to, did not move or adjust. I mean, I can work around this, no biggie. Bu thought as you did... Link to comment Share on other sites More sharing options...
Alaskan_Son Posted February 3, 2021 Share Posted February 3, 2021 Ah, you didn’t say you were GROUP selecting. That changes things. The behavior is different during a group select and I believe it always has been. Link to comment Share on other sites More sharing options...
mtldesigns Posted February 3, 2021 Author Share Posted February 3, 2021 Ah, and your right. Just did one, not a group, worked as it should. Link to comment Share on other sites More sharing options...
