mtldesigns 50 Posted February 3 Curious as of late.. but it seems that IN THE PAST when moving a wall via a dimension, that most of the time any connected wall moved as well.. esp. exterior walls. Why doesn't it do this any more? Share this post Link to post Share on other sites
mtldesigns 50 Posted February 3 sorry, not yelling in subject.. forgot to turn off caps Share this post Link to post Share on other sites
Alaskan_Son 2599 Posted February 3 It’s always about WHICH wall you select and which of the associated dimensions you click on. you can either select the wall and then click on a parallel dimension in which case you will be changing its length or you can click on a perpendicular dimension in which case you would be MOVING the wall along with any connected walls ends. Share this post Link to post Share on other sites
mtldesigns 50 Posted February 3 52 minutes ago, Alaskan_Son said: or you can click on a perpendicular dimension in which case you would be MOVING the wall along with any connected walls ends. that's what I thought also, but just like the example, I picked the ext. and railing wall, and picked the dim that was perp to it.. both of the walls moved, but the ext. and rail wall that was perp/connected to, did not move or adjust. I mean, I can work around this, no biggie. Bu thought as you did... Share this post Link to post Share on other sites
Alaskan_Son 2599 Posted February 3 Ah, you didn’t say you were GROUP selecting. That changes things. The behavior is different during a group select and I believe it always has been. Share this post Link to post Share on other sites
mtldesigns 50 Posted February 3 Ah, and your right. Just did one, not a group, worked as it should. Share this post Link to post Share on other sites
