Remove drywall from ceiling in specific rooms
Cannonkd
The room below on floor 1 is defined with an invisible wall in line with the railing wall above on floor 2.
The room next to the railing room on floor 2 is designated as "open below" to get the cathedral ceiling.
Build your floor and ceiling framing to the specs that reflect your construction.
Open the Dialoge Box for the Room on floor 1 and delete the ceiling finish in the structure tab.  This will expose those floor joists above.
