Shan-Blackstone Posted January 20, 2021 Share Posted January 20, 2021 Hi All: I would appreciate any help with this issue I have been having with providing dimensions for elevations. For some reason, when I go to place a dimension (it seems to be of any kind, manual, NKBA, etc...), as I am laying it out, it is nice and clear, but as soon as I complete the dimension, the end result that is left is "blurry" and is somewhat hard to decipher when the elevation is printed. I have provided a pic of the end result of my dimensioning tools in my elevations. What I am I doing wrong? I work with another couple of desginers in the same office that don't have this problem, their dimensions come out nice and clear. Again, any help is appreicated. TIA!!! Blurred Dimensions.pdf Link to comment Share on other sites More sharing options...
Chopsaw Posted January 20, 2021 Share Posted January 20, 2021 It appears to be a resolution problem in the entire PDF. What settings are you using to produce the PDF ? Link to comment Share on other sites More sharing options...
Shan-Blackstone Posted January 20, 2021 Author Share Posted January 20, 2021 Hi: Thanks for your reply! Sorry, I'm not entirely sure what you mean. How would I be able to tell what settings are being used for PDF's? I have been using this program for years, but I primarily use it for kitchen and bath design, so I don't know all of the in's and out's of the program, unfortunately. Thank you for your help. Link to comment Share on other sites More sharing options...
Shan-Blackstone Posted January 20, 2021 Author Share Posted January 20, 2021 Perhaps I should also mention that my layouts create nice text and dimensions, it is only in the elevations that it comes out blurry. Thanks again, Link to comment Share on other sites More sharing options...
Chrisb222 Posted January 20, 2021 Share Posted January 20, 2021 How did you send to layout? It looks like you chose "Current Screen" > "Live View" or "Current Screen As Image" If so, send "Current Screen" > "Plot Lines" and see if it's better Link to comment Share on other sites More sharing options...
Chopsaw Posted January 21, 2021 Share Posted January 21, 2021 3 hours ago, Shan-Blackstone said: Sorry, I'm not entirely sure what you mean. How would I be able to tell what settings are being used for PDF's? Try these settings or post the ones you are using. It may also be helpful to take a look at the plan and layout files. Link to comment Share on other sites More sharing options...
Shan-Blackstone Posted January 22, 2021 Author Share Posted January 22, 2021 Hey All: Thank you for any suggestions. We figured it out in our showroom that I must have changed a setting of some sort on the template plan I had been using. If I use an entirely new plan, the measurements turn out nice and clear. A fairly simple fix, but still not sure what I had changed for the dimensions and text to show like that on the plans. Again, thanks for the help! Link to comment Share on other sites More sharing options...
