Changing ceiling heights
StepOneDesign
Hello
Have version 12.
I had to change my ceiling heights on a full plan - I did this in the default settings and it shattered all my elevations - dimensions and weird stuff happening.
I take it this wasn't the place to do it?
HELP!
I can go back and capture backup before I did this - but does this mean that I have to redo all my interior elevations?
Thank you in advance for any advice.
29 minutes ago, StepOneDesign said:
Hello
Have version 12.
HELP!
Does anyone have advice - do I have to go back and change all my elevations (which have been sent to layout) to suit?
OR is there something I did wrong in the process?  I HAVE searched this issue - but to no avail.
SORRY SOLVER for not putting an x in front of the 12.  AND I added this to my signature.  Thought it was easier in the actually message for everyone to read.
Thank you.
WALLS MISSING
EVEN AFTER UPDATING VIEWS - MISSING INFO, DIMENSIONS WRONG, ELEVATION GHOSTED, NOTE THAT THE ELEVATION IS NOW "DROPPED" ESSENTIALLY.
I CAN SEND MORE - BUT THIS IS THE GENERAL IDEA.  ALL 37 SHEETS HAVE ERRORS, UNLINKED ELEVATIONS, PLAN VIEWS ETC.
Here's a good example.  Tile (I use backsplash tool) missing on wall elevation.  Height of towel bar has to be adjusted. etc.
AGAIN TO BE CLEAR - I am sure it is what I am doing wrong.....not the program?
To repeat my question, is it typical to have to go back and redo all the elevations, height placement, dimension snaps if you change ceiling heights?
