ChiefuserMathews 3 Posted December 15, 2020 When I try to insert the waste container into the cabinet it ends up on the top of the cabinet (file attached) what am I doing wrong? Trying to follow the latest webinar "Customizing Cabinets & What's Coming Next". Any suggestion or help? del waste container.plan Share this post Link to post Share on other sites
solver 1636 Posted December 15, 2020 7 minutes ago, ChiefuserMathews said: what am I doing wrong? Not following the instructions It's helpful to have a link to the video, and a time to forward to so we can see what you see. Share this post Link to post Share on other sites
MarkMc 541 Posted December 15, 2020 8 hours ago, ChiefuserMathews said: what am I doing wrong I did not watch the video so can't say as to that. First you have the cabinet set to have a door, pullouts go into drawers. IF you did place a pullout on the door it would stay on the back of the door when the door opened and not pullout. It could be placed as a rollout in the shelf tab but this one doesn't open like a rollout when selected from the RAS library. Second and most important-somehow your symbol has been defined as "Inserts into Counterrop". The one from the library does not so either you imported it or changed the symbol options. So- define as drawer , then specify the drawer box Left to right- yours, attached to back of a door, defined as rollout in shelf tab, drawer with defined as drawer box 1 Share this post Link to post Share on other sites
ChiefuserMathews 3 Posted December 15, 2020 8 hours ago, solver said: Not following the instructions It's helpful to have a link to the video, and a time to forward to so we can see what you see. This is the best answer I ever received. Eric, you always try to help and in the forefront, I agreed, appreciated that. But I am not an expert like you. That's why I post those silly questions. I know I am doing something wrong. If I could figure out I would not act like a fool asking those questions. Anyways thank you for your help. A detailed helping reply came from Mark. Have a great day. Share this post Link to post Share on other sites
ChiefuserMathews 3 Posted December 15, 2020 21 minutes ago, MarkMc said: I did not watch the video so can't say as to that. First you have the cabinet set to have a door, pullouts go into drawers. IF you did place a pullout on the door it would stay on the back of the door when the door opened and not pullout. It could be placed as a rollout in the shelf tab but this one doesn't open like a rollout when selected from the RAS library. Second and most important-somehow your symbol has been defined as "Inserts into Counterrop". The one from the library does not so either you imported it or changed the symbol options. So- define as drawer , then specify the drawer box Left to right- yours, attached to back of a door, defined as rollout in shelf tab, drawer with defined as drawer box Hi Mark, thank you very much for your detailed helpful reply. That is awesome. Much appreciated that. Let me try your steps. I know I am doing something wrong, but could not figure out. Once again thank you. Have a great day. Share this post Link to post Share on other sites
solver 1636 Posted December 15, 2020 1 hour ago, ChiefuserMathews said: This is the best answer I ever received. Eric Before I replied, I watched the video and followed the steps shown, and was successful in placing the pullout within the cabinet. I'd never done this, but since it worked, I knew that you were simply missing a step. Share this post Link to post Share on other sites
