Steve_Nyhof Posted December 3, 2020 Share Posted December 3, 2020 I'm running into something strange. I have a breezeway with exterior walls outside the foyer with exterior walls. This breezeway is a porch, and I also have a porch outside the breezeway. But when I place a door, it puts in an interior door. How can I force an exterior door. When will the Max upload be increased? More than half the plans I want to upload are too large. Anyway... https://drive.google.com/file/d/1MiP7PXJSQYPIi2QCicTqDCYbpM4EWxzi/view?usp=sharing Link to comment Share on other sites More sharing options...
Steve_Nyhof Posted December 3, 2020 Author Share Posted December 3, 2020 Just now, solver said: We often don't need the entire plan. Create a small demonstration plan, or use Edit Area to cut out a section of a larger plan to create a new plan with. And Zip helps too. Great idea! Will do Link to comment Share on other sites More sharing options...
Steve_Nyhof Posted December 3, 2020 Author Share Posted December 3, 2020 Also, the exterior casing isn't available. Link to comment Share on other sites More sharing options...
DzinEye Posted December 3, 2020 Share Posted December 3, 2020 8 minutes ago, stevenyhof said: But when I place a door, it puts in an interior door. How can I force an exterior door. That is odd... Don't know why it's happening, but if you change say that short porch 'wall' to 'no room definition' you'll get your exterior door. Link to comment Share on other sites More sharing options...
Steve_Nyhof Posted December 3, 2020 Author Share Posted December 3, 2020 1 minute ago, DzinEye said: but if you change say that short porch 'wall' to 'no room definition' you'll get your exterior door. Its not working for me ??? Link to comment Share on other sites More sharing options...
DzinEye Posted December 3, 2020 Share Posted December 3, 2020 Just now, stevenyhof said: Its not working for me ??? Hmm?.. but I noticed you lose the beam doing that anyway. Try changing 'porch' to 'garage'... that works too Link to comment Share on other sites More sharing options...
Steve_Nyhof Posted December 3, 2020 Author Share Posted December 3, 2020 I wouldn't mind so much on a sided wall, but I need the casing removed for the stone. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted December 3, 2020 Share Posted December 3, 2020 8 minutes ago, stevenyhof said: Also, the exterior casing isn't available. Didn't open your plan, but for this one, read the options on the General Panel. Read very carefully down near the bottom of that panel. Link to comment Share on other sites More sharing options...
Steve_Nyhof Posted December 3, 2020 Author Share Posted December 3, 2020 Changing to Garage worked!!! Thank you Link to comment Share on other sites More sharing options...
Steve_Nyhof Posted December 3, 2020 Author Share Posted December 3, 2020 2 minutes ago, Alaskan_Son said: Didn't open your plan, but for this one, read the options on the General Panel. Read very carefully down near the bottom of that panel. On the door? this is when the room was a porch Link to comment Share on other sites More sharing options...
Steve_Nyhof Posted December 3, 2020 Author Share Posted December 3, 2020 Now it is a garage room Link to comment Share on other sites More sharing options...
DzinEye Posted December 3, 2020 Share Posted December 3, 2020 Just now, stevenyhof said: Changing to Garage worked!!! Thank you You could make either of those two joined porches a garage and it works. Link to comment Share on other sites More sharing options...
Steve_Nyhof Posted December 3, 2020 Author Share Posted December 3, 2020 Just now, DzinEye said: You could make either of those two joined porches a garage and it works. Thank you Mark! I'm on my way again Link to comment Share on other sites More sharing options...
Alaskan_Son Posted December 3, 2020 Share Posted December 3, 2020 5 minutes ago, stevenyhof said: On the door? this is when the room was a porch Yes. On that panel. Link to comment Share on other sites More sharing options...
Steve_Nyhof Posted December 3, 2020 Author Share Posted December 3, 2020 1 minute ago, Alaskan_Son said: Yes. On that panel. I changed my room back to porch so I could get that door. I checked the option for Interior Doors, and it changed to an exterior door. hmmm - it must be for something else also as that did not catch my eye. Thank you Michael! Link to comment Share on other sites More sharing options...
Dermot Posted December 3, 2020 Share Posted December 3, 2020 Chief will create either an interior or exterior door based on the room types on each side of it. If the door is between an exterior room type and an interior room type, it will be an exterior door. If it is in between two interior room types, it will be an interior door. If the door is between two porches, like it is in your plan, the program considers this an interior door. I really can't say why, but my guess is that it has always been this way and that this is not very common. The good news is that you can still specify all of the settings (such as the casing and materials) just like you can for an exterior door. All you need to do is check the "Separate Trim and Materials on Each Side" option that Michael was hinting at. The other solution is to change the room type of the fully enclosed room to some interior room type. Link to comment Share on other sites More sharing options...
Steve_Nyhof Posted December 3, 2020 Author Share Posted December 3, 2020 5 minutes ago, Dermot said: Chief will create either an interior or exterior door based on the room types on each side of it. If the door is between an exterior room type and an interior room type, it will be an exterior door. If it is in between two interior room types, it will be an interior door. If the door is between two porches, like it is in your plan, the program considers this an interior door. I really can't say why, but my guess is that it has always been this way and that this is not very common. The good news is that you can still specify all of the settings (such as the casing and materials) just like you can for an exterior door. All you need to do is check the "Separate Trim and Materials on Each Side" option that Michael was hinting at. The other solution is to change the room type of the fully enclosed room to some interior room type. Very good. Thank you! Now I know that I can address this when I run into it again. Link to comment Share on other sites More sharing options...
