Rashid_Garuba Posted December 3, 2020 Share Posted December 3, 2020 On 12/2/2020 at 9:28 PM, stevenyhof said: What does PBR stand for? Getting that from the other post. Expand Steve, Physically Based Rendering was added to Chief a couple of versions ago.. The intent I think is to address what you are experiencing, the wait for rendering passes. PBR is MUCH, MUCH faster (essentially live renders) than Ray-tracing with quality that is very close to better.. ONCE you figure it out.. Graham is excellent at it... Many have stopped Raytracing once PBR is learned.. PBR VS Raytracing - General Q & A - ChiefTalk Forum (chiefarchitect.com) ps. check your messages.. Link to comment Share on other sites More sharing options...
Steve_Nyhof Posted December 3, 2020 Author Share Posted December 3, 2020 On 12/3/2020 at 3:09 PM, robdyck said: Before you raytrace that scene, you should see if you can adjust the facet angle of the drywall arch. Try 2 degrees, it'll smooth it out nicely. It looks like you used a p-solid, right? Expand I have seen how to adjust that before and cannot find it again Link to comment Share on other sites More sharing options...
robdyck Posted December 3, 2020 Share Posted December 3, 2020 On 12/3/2020 at 3:56 PM, stevenyhof said: I have seen how to adjust that before and cannot find it again Expand uncheck and replace the value with 2 Link to comment Share on other sites More sharing options...
Steve_Nyhof Posted December 3, 2020 Author Share Posted December 3, 2020 I must have the wrong shape or solid - I used a polyline solid I believe Link to comment Share on other sites More sharing options...
Steve_Nyhof Posted December 3, 2020 Author Share Posted December 3, 2020 hmmm - I closed it and opened it again and now it shows up - thank you Link to comment Share on other sites More sharing options...
Alaskan_Son Posted December 3, 2020 Share Posted December 3, 2020 On 12/3/2020 at 7:16 PM, stevenyhof said: hmmm - I closed it and opened it again and now it shows up - thank you Expand Note the name of the TAB you used. Link to comment Share on other sites More sharing options...
Steve_Nyhof Posted December 3, 2020 Author Share Posted December 3, 2020 On 12/3/2020 at 7:17 PM, Alaskan_Son said: Note the name of the TAB you used. Expand Ah! Wonder why it came up that way first? Anyway, Now I know what to look for. I don't use arches often. Thank you! Link to comment Share on other sites More sharing options...
Steve_Nyhof Posted December 3, 2020 Author Share Posted December 3, 2020 Ah! I see what I did... I did not have the arc segment selected Link to comment Share on other sites More sharing options...
