link Library symbols to hotkey
DianeP
20 hours ago, Chopsaw said:
Not so sure you can have those on hot keys but you can set them up on a Library Object toolbar.
There really should not be any reason that once you set up the Library Object tool that you could apply a hot key to it.
That might make a good suggestion for an up coming version.
Thanks Chopsaw!  I will do this and add it as a suggestion.  Is there a way to add a ChiefTalk forum thread to the suggestion box directly.  If not, then that would be a suggestion I would make to Chief Architect.
Yes that would be great. You can just highlight and copy the link in your browser to reference the whole thread or there is a little tool in the top right of each comment to link one of those specifically.
