mtldesigns Posted November 23, 2020 Share Posted November 23, 2020 Did you guys know there are 100's of post in regard to railings? I have a 10" ICF wall (actually any wall this would apply). Even though my main wall extends past a railing wall by 6" (and I tried 12"), as soon as I extend the rail wall, the main wall cuts back. Where or where is the setting that tells the rail wall that it does not have permission to cut any wall back? After all its only a railing wall... I tried to manipulate and adjust by dragging handles, that did not work. Link to comment Share on other sites More sharing options...
Chopsaw Posted November 23, 2020 Share Posted November 23, 2020 Not so sure they have fixed that yet. Try a 0" width room divider across the end of your railing wall and nudge it in as close as 1/64" with your arrow keys while the room divider is selected and connected to the railing wall. 1 Link to comment Share on other sites More sharing options...
mtldesigns Posted November 23, 2020 Author Share Posted November 23, 2020 20 hours ago, Chopsaw said: Not so sure they have fixed that yet. Try a 0" width room divider across the end of your railing wall and nudge it in as close as 1/64" with your arrow keys while the room divider is selected and connected to the railing wall. Thanks Chop.. I did use the room divider after your suggestion, but still gave me issues. So I reversed the divider and put it where I needed the ICF wall to be... then extended rail wall. Worked perfectly.. thanks for pointing me in the direction of that line. Link to comment Share on other sites More sharing options...
