jonow6 Posted November 11, 2020 Share Posted November 11, 2020 I am having trouble getting the floor fill style to show on my floor plan. Under layers I have the "Floor Surfaces" layer turned on. Under each room I have gone into the Room Specs>Structure>Floor>Floor Finish and added a fill style, but for whatever reason I can't seem to get it to display... See the attached screenshot for reference Any ideas?.. Link to comment Share on other sites More sharing options...
joey_martin Posted November 11, 2020 Share Posted November 11, 2020 Check the layer for ROOMS. That layer needs to be on for those patterns to show. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted November 11, 2020 Share Posted November 11, 2020 Those fills are used for section views and are only created if you use the Auto Detail tool. If you want a fill to show up in your room in plan view, add that fill to your actual room using the Fill Style tab (not the Structure tab). 1 Link to comment Share on other sites More sharing options...
jonow6 Posted November 11, 2020 Author Share Posted November 11, 2020 Brilliant! Thanks Not sure how I missed that Link to comment Share on other sites More sharing options...
