TannerS
Gap Between First and Second Floor
I need some help with a two-story house that I am playing around with. I have tried every solution that I have found online and nothing has worked for me. The first two links are the methods that I have already tried in an attempt to resolve the issue. I have also gone to "Room specification>Structure" and tried to change the second "floor" height but it just automatically adjusts the "Ceiling Below" and I am left with the same problem. I feel like if I could lock the ceiling height and then change the floor height then I might be able to resolve the issue. I have attached a picture of the Orthographic Full Overview, the "Wall Type Definitions" from the solution provided in link 1, and "Room Specifications" where I tried to change the floor height. I am not in any big rush to get this fixed, but any help is appreciated. Thank y'all.
https://www.chiefarchitect.com/support/article/KB-00038/resolving-a-gap-between-floors-in-camera-views.html
https://chieftalk.chiefarchitect.com/topic/6925-gap-between-floors-in-3d/
TannerS
Chief Architect Premier X11
post the plan and somebody will answer post haste
Hey Tanner,
I guess I'm not sure what the question is?  Are you a talking about the gap showing in the ortho view?  If so, that will fill in when you built your frame structure (the 12 5/8" dim on your dbx).  Until you build your frame, that will not show "filled" in.  IF you have built the frame, try turning on your framing layers (floor)
Thank you Michael! That worked for me. I sort of wish that it had been a more complicated problem because now I feel a little dumb. Thanks for the speedy reply and help.
Not dumb if you didn't know.. shoot, I asked a dumb one myself today...  So all is cool.
    28847
    SWinteriordesign
    SWinteriordesign
  • Similar Content
    • By robdyck
      I can't remember, or quickly find which layer controls the text portion of some electrical symbols. For my electrical set, most layers are light gray...and one of them is affecting the symbol display. It's gray as well, and of course, I want it black.
      Can anyone help me out?
    • By robdyck
      I can't get a skylight to build a square shaft when placing a skylight into a roof plane when the room does NOT have a flat ceiling. In my A-frame project, the ceiling is supplied by the roof and part of the skylight dbx is greyed out. Skylight works fine when its over a flat ceiling. Has anyone else run into this before?
    • By robdyck
      If I mull 2 exterior doors together in order to make a patio door that has a mullion, I can't see an option to specify this door as 'exterior' or 'interior'. This affects my schedules as I use a separate schedule for exterior and interior doors, because they're usually from unrelated suppliers. Am I missing something?
      I'd love the ability to be able to add a mullion to a double door.
      I now see that can be controlled in the schedule tab by exploding the Door Tab.
    • By robdyck
      I have a text macro in a garage plan that references the area of a polyline. In layout, that macro appears blank unless the plan file is open. Is that normal?
      I needed to open the layout file only (or so I thought) and make a few adjustments before printing.
    • By Evolution
      This project was set up for paper size Super B 13X19 (because I can print that here in this office for ready check). The client (builder) has decided he wants me to change my layout sheet size to Arch D 24X36, so his subs could read and scale the drawings. I wasn't sure I did this right (after reading what few post I could find), I opened my layout>page "0" reset the print to page size to Arch "D" 24X36, which of course changed how my layout template set to 13X19 fits. I then edited my borders and title block etc., to fit the new layout size.  I then went to each additional sheet that I had added notes, additional info for title block, most everything else fit the new paper size ok.  I can't print a trial drawing but the PDF's I printed with the new sheet size appear to be ok. Does the method I used make sense? I'll send him the PDF set of construction drawings, and he can have them printed. I had previously set up a layout template formatted to Arch "D" but I wasn't sure how to get all my plans and details transferred to the new layout template, since you can only have one layout open at any given time?
