fireplace on wall elevation
winterdd
My guess is that your fireplace is not in the same room as your wall elevation camera.  Wall elevations are for a single room only and will exclude objects that are not in that room.
You would need to post a plan for anyone to know for sure.
You could either use a cross section camera (because these will use the whole model), or change your room definition so that the fireplace is actually in the room (but this can have other side effects), or modify the fireplace so that it is in the same room as the camera.
This really makes alot of sense. Good explanation.
