BnCKelley Posted October 28, 2020 Share Posted October 28, 2020 Good afternoon everyone, I am trying to flock together three casement windows with a transom. My first ordeal is I can't blend the transom into the Windows like I thought it should do and this may not workout like I'm thinking but I'm also trying to block the four windows together and it won't do it because of an overlap and a spacing issue. Anyone have any clues to what I'm doing wrong? Link to comment Share on other sites More sharing options...
BnCKelley Posted October 29, 2020 Author Share Posted October 29, 2020 Yes I want to mull this collection together but it is saying they're overlapping. Is my signature showing up? And is there a way to permanent turn on the Notify me of replies button? Thanks Link to comment Share on other sites More sharing options...
GeneDavis Posted October 29, 2020 Share Posted October 29, 2020 Close plan file. If over 25 Mb then zip it. If under, no zip needed. Attach it to to your next post. We'll get 'em mulled. Link to comment Share on other sites More sharing options...
Dermot Posted October 29, 2020 Share Posted October 29, 2020 See if this tech article helps: https://www.chiefarchitect.com/support/article/KB-00525/creating-a-mulled-door-and-window-unit.html If not, then you will probably want to post a simple plan that demonstrates the problem you are having. Someone on this forum would then be able to quickly determine what you are doing that is preventing the windows from being mulled. If all else fails, then you might want to contact our technical support team during normal business hours. Link to comment Share on other sites More sharing options...
BnCKelley Posted October 29, 2020 Author Share Posted October 29, 2020 Ok but it'll be later tonight possibly. I got it to work with another set now but then had another that wouldn't??? I know it's something I'm doing, just not sure what. Thanks bud Link to comment Share on other sites More sharing options...
