Simple Shed door hardware
rck-tech
8 minutes ago, rck-tech said:
If the Solver, the KING,  of Chief Architect does not know!  I have a feeling that means it can't be done ..
Thank you,
It can totally be done but would require creating the door as symbol and setting the appropriate origin offsets to get it out flush with casing. You would have to do the same with the hinges and handle (set offsets).
Left is a cabinet, right is symbol set to insert into wall made from cabinet. Just used strap hinges from library. If you want something better then need to make the hinges. If you want them to open properly need to make the part on the door separate from the part on the casing. There are other ways, this took a few minutes.
Shed Door.plan
