decorators3 Posted October 14, 2020 Share Posted October 14, 2020 HI I imported a multicolored jpg for my vessel sink to change from white . however it changed every glass in my library to the same multi color. How do I eliminate this Thanks Link to comment Share on other sites More sharing options...
DavidJPotter Posted October 14, 2020 Share Posted October 14, 2020 I doubt that "... however it changed every glass in my library to the same multi color." Importing a custom material to the Library Browser cannot do this. What I think you meant is that when you applied that custom material to the sink you used the "Eye dropper" or "Material Painter" tool in the wrong "Mode". Both of those tools have four application modes: the default is "Component Mode" and this mode just applies the intended material to whatever surface you click on with the tool active. The second mode is called "Object Mode" which then applies that intended material to the entire object clicked on. Then there is "Room Mode" that will apply the intended material to all similar objects in the room. Then there is " Floor Mode" which then applies the intended material to all similar object on the floor you are on. Finally there is "Plan Mode" which is apparently what you mistakenly used used to apply your custom material to a single sink but "Plan Mode" is programmed to apply the selected material to all similar objects in the ENTIRE PLAN with a single click. I believe that is what you did. The above is my best guess as to what you are now complaining of. For more data please click on this link to Help Articles about using the eye dropper and material sprayer please. DJP Link to comment Share on other sites More sharing options...
decorators3 Posted October 14, 2020 Author Share Posted October 14, 2020 thank you! Link to comment Share on other sites More sharing options...
decorators3 Posted October 14, 2020 Author Share Posted October 14, 2020 hi Here is what is happening.. all my glass doors in the library show this colored glass - I imported the color to use on a vessel sink. as you can see even a regular slab door with glass shows this multi colored blue.. Still cant get rid of it.. I imported it thru the define material - under Texture - I browsed my desktop and uploaded it to color the sink but I don't know how it got into every glass in my library. If I use try to use standard glass in component mode nothing happens. I have neve had this issue before .. If I go to EDIT and reset defaults will that help?? Any help is appreciated Thanks Levina Link to comment Share on other sites More sharing options...
decorators3 Posted October 14, 2020 Author Share Posted October 14, 2020 thanks.. It worked!!!!! Link to comment Share on other sites More sharing options...
