PIR-Designs Posted October 1, 2020 Share Posted October 1, 2020 (edited) Hi All, I just suddenly can't remember if we have a way to show the length of a wall while you're drawing it. I work with so many different types of design software and normally, I can see the length of a wall when I'm drawing it. That way, when I get close to the specific length I want, I can slow down until it's perfect (or right click and specify the exact length after drawing it). Did we ever have that option with CA so that when you're drawing a wall with your cursor/mouse that you're seeing the length of the wall as you create it? If so, where in the setting would I specify that? Thanks Lauren X11, Windows 10, PC Edited October 1, 2020 by MilitaryTVgirl Showing that the question has been answered Link to comment Share on other sites More sharing options...
justmejerry Posted October 1, 2020 Share Posted October 1, 2020 I believe if you have your temporary dimensions on it shows. If you hit tab while drawing you can set exact length. 1 1 Link to comment Share on other sites More sharing options...
PIR-Designs Posted October 1, 2020 Author Share Posted October 1, 2020 YES! justmejerry! That was it! You rock! Thank you a thousand times! Greatly appreciated! Lauren Link to comment Share on other sites More sharing options...
Kbird1 Posted October 2, 2020 Share Posted October 2, 2020 8 hours ago, justmejerry said: I believe if you have your temporary dimensions on it shows. If you hit tab while drawing you can set exact length. may need to check this box too though..... 1 Link to comment Share on other sites More sharing options...
