Rid me of this unwanted window trim
GeneDavis
I did the splayed wall surround for a basement window in an ICF wall.  Set the window depth to 4-9/16", created an outer ICF wall at 4-9/16" total thickness, an inner, broke walls and did the double wall work, did a molding for the splay, only have the molding as my interior casing, but I have an unwanted lintel or something that I cannot delete.
In section view it is on the inside face of the wall and also against the outside face of the inner wall.
File attached.  It is in the floor 0 bedroom at plan top left.
Hickey SBR hipped roof.zip
Your inner wall pass through has a lintel on it.  Pull the wall inside the room so you can see what is going on.  The lintel follows that wall.  Click on the pass through and turn off the lintel.  They you can move it back into place against the outer wall.
I cannot get the inner wall in a position to see and click its pass-thru for editing.  In plan view, I select the inner wall, move it 12" x-direction to get it in the room, and it shows no pass-thru.
What's the trick?
And Eric, how did you get your result?
