Some PBR Walls Glow
Adam_Gibson
1 hour ago, Adam_Gibson said:
That makes sense. It may have something to do with the sun. I dialed it back and it's improved. However, some of the walls this happens to are interior walls. It's even happening with some casing.
Any number of things can cause this, often from user error with a slight workflow adjustment needed. Happens most often in template plans, being too far from 0,0 origin, building envelop not properly closed, improper wall designations etc. Too many to list, best to post a .plan file.
33 minutes ago, Adam_Gibson said:
The plan is too big to attach but here's a link for anyone willing to take a look. https://www.dropbox.com/s/iks7ssfznbsuez0/Untitled 3.zip?dl=0
Problem is that the envelope isnt full closed, likely the parapet roof. Light comes in to the interstitial space and the wall tops pick up the sunlight
