hhdesigner Posted September 10, 2020 Share Posted September 10, 2020 Is there a way to customize a pantry cabinet on the inside, but still have (2) full height doors? We need upper half of pantry to be full width adjustable shelves, bottom half to be spit vertically with pull out baskets on one side and roll shelves on the other side. We don't want to doors to be split horizontally. Link to comment Share on other sites More sharing options...
MarkMc Posted September 16, 2020 Share Posted September 16, 2020 On 9/10/2020 at 4:52 PM, hhdesigner said: Is there a way to customize a pantry cabinet on the inside, but still have (2) full height doors? Just saw this today, then after I did it saw you are on X11-I did this in 12 but principal remains. Simplest way to do this is to use a custom cabinet door- place door in plan change height to what you want final height of door to be convert to symbol, cabinet door, advanced options go to sizing panel and set the Height stretch plane somewhere beyond the height of the door Don't forget to change material to "Use Default" Place this door on cabinet, alter cabinet so you have a left and right door with the top section as opening at whatever height you want. Change shelves in each door section to manual, set as rollout and change symbols used as desired. 2 1 Link to comment Share on other sites More sharing options...
DzinEye Posted September 17, 2020 Share Posted September 17, 2020 19 hours ago, MarkMc said: Simplest way to do this is to use a custom cabinet door- Wow Mark... very impressive bit of manipulation there. Link to comment Share on other sites More sharing options...
hhdesigner Posted September 18, 2020 Author Share Posted September 18, 2020 Thank you Mark! I had to do a bit more manipulating as they decided they wanted shelves on the back of the doors, too, but finally got the look they wanted. Link to comment Share on other sites More sharing options...
