rockyshepheard Posted September 2, 2020 Share Posted September 2, 2020 I have a wall and a nice gable roof. I hear CA abhors a vacuum and readily fills the space with wall up to the roof. For some reason (user error), this wall is happy to remain at the ceiling height. Is there a most common cause of this 'wall laziness'? Thank you for any responses. Rocky Link to comment Share on other sites More sharing options...
Ridge_Runner Posted September 2, 2020 Share Posted September 2, 2020 Do you have "Auto Rebuild Attic Walls" on? Found in Defaults/General Wall Defaults/Automatic Walls, toward the bottom. Should be "Defaults/Walls/General Wall Defaults/Automatic Walls, toward the bottom. Link to comment Share on other sites More sharing options...
Chief16Designer Posted September 2, 2020 Share Posted September 2, 2020 You could open the wall check ballon through celling above 1 Link to comment Share on other sites More sharing options...
rockyshepheard Posted September 2, 2020 Author Share Posted September 2, 2020 2 hours ago, Ridge_Runner said: Do you have "Auto Rebuild Attic Walls" on? Found in Defaults/General Wall Defaults/Automatic Walls, toward the bottom. Should be "Defaults/Walls/General Wall Defaults/Automatic Walls, toward the bottom. 1 hour ago, Chief16Designer said: You could open the wall check ballon through celling above 1 hour ago, solver said: I changed 1 thing that has nothing to do with the wall. The hint is in the image. What's different when compared to your plan? Thanks all! Ridge Runner- I did have "auto rebuild attic roofs" on in the defaults. Chief16Designer- Checking "Ballon through ceiling above" worked! Solver-The only thing I see is the window is lower in the Z direction. see attached. Link to comment Share on other sites More sharing options...
rockyshepheard Posted September 2, 2020 Author Share Posted September 2, 2020 Thanks Solver et al. In summary... if you check "Roof Over Room" that creates gable wall without "Balloon Through Celling Above" being checked. RESULT: gable wall and roof over room and if you do not check "Roof Over Room", you can get gable wall by checking "Balloon Through Celling Above. RESULT: gable wall with no roof over room. I see. Thx Link to comment Share on other sites More sharing options...
