Canuck Posted August 24, 2020 Share Posted August 24, 2020 I have a HP 520T printer.. When I print from the CAD file, the PDF either doesn't completely print or doesn't print at all. I've even converted the CAD to a PDF file and tried printing from that and same thing occurs. Any ideas on what it is I'm doing wrong? Should i try Adobe PDF to convert? Truly stumped. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted August 24, 2020 Share Posted August 24, 2020 What do you mean by “print from the CAD file”? Walk us through how you are printing. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted August 24, 2020 Share Posted August 24, 2020 Also, what do you mean by “converted the CAD to a PDF file“? And does the embedded PDF show up in that resulting PDF before printing? Link to comment Share on other sites More sharing options...
Canuck Posted August 24, 2020 Author Share Posted August 24, 2020 You can either print to PDF from Chief and send them to the ENG / Contractor. Or print the file layout. It either partially prints or the embedded PDF won't print at all.. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted August 24, 2020 Share Posted August 24, 2020 You’re not providing enough detail. I don’t know if you’re printing from plan, printing from layout, printing the current screen, using Chief’s built in PDF printer, using another PDF printer, etc. etc. in addition, you haven’t answered the question as to whether or not you can see the embedded PDFs in your newly printed PDF file or not. Is it the PDF they don’t show up on, it just the paper? And what color and lineweights are the embedded PDF elements composed of? Link to comment Share on other sites More sharing options...
builtright3 Posted August 24, 2020 Share Posted August 24, 2020 I have the same printer; I found it best for me to print layout to "Chief Architect Save As PDF" an then print on paper from there. You should be able to print it in all the different ways that you talked about though. Usually when I have problems with not printing or printing partial pages it is because my computer isn't properly connecting and/or formatted to the printer. I will usually restart the printer and the plotter and that will straighten it out. Link to comment Share on other sites More sharing options...
Lmlowery Posted August 25, 2020 Share Posted August 25, 2020 I am having the same problem. I have the HP T830 plotter, and what little research into this issue I have done seems to suggest it could be a printer driver, but a new driver did not solve the problem. However, I have had some success getting inserted PDF's to fully print by creating a PDF using Chief's save as PDF feature, then opening the PDF in acrobat or whatever PDF software you use, open the print dialog, choose your printer, click on the "advanced" tab, select "print as image". If I come up with anything else that works I will post it here. Link to comment Share on other sites More sharing options...
Canuck Posted August 25, 2020 Author Share Posted August 25, 2020 On 8/24/2020 at 10:00 PM, builtright3 said: I have the same printer; I found it best for me to print layout to "Chief Architect Save As PDF" an then print on paper from there. You should be able to print it in all the different ways that you talked about though. Usually when I have problems with not printing or printing partial pages it is because my computer isn't properly connecting and/or formatted to the printer. I will usually restart the printer and the plotter and that will straighten it out. Expand Thank you Joe, you nailed it. I'm not sure why this happens, but neither am a software / hardware guy. Link to comment Share on other sites More sharing options...
