APTArchitect
Adding material options to furniture
I would like to change the fabric material for this barstool (Lincoln, attached file) separate from the wood frame material. The item only has one material choice. I tried to export as a DWG, but that did not work. Anybody know if and how this can be accomplished? Working with CA x12.
lincoln.calibz
Yes Michael did a great video of that a while back.  It can also be done in Sketchup.
You can alter this by using 2 copies of the same symbol.
  • use the delete surface tool to remove all the faces of the seat. Then, convert this to a new symbol and place.
  • use the delete surface tool to remove all the faces of the frame. Then, convert this to a new symbol and place.
  • assign different materials to each symbol, then overlap the 2 new symbols and convert to a new symbol.
This symbol will probably be easier to modify in sketchup. The frame has so many unnecessary faces.
It is not so bad Rob you can just turn the smoothing angle way up before using the delete surfaces tool.  Not sure Michael covered that in the video I posted.
Totally forgot about that. I haven't done this in quite awhile. Thanks Chop!
1 minute ago, APTArchitect said:
@robdyckAwesome, thank you so much!
You're welcome!
Guest
You are commenting as a guest. If you have an account, please sign in.
Reply to this topic...
  Only 75 emoji are allowed.
    28425
    ChiefProBrian
    ChiefProBrian
