vaulted ceiling
decorators3
Hi
I have attached a floor plan showing 2 rooms
- one room has flat ceiling 10' in height
- second room has vaulted ceiling 24' height at center of ceiling
My issue is I have an invisible wall to separate the two rooms ,but when i remove remove the invisible wall section my vaulted ceiling turns to a flat ceiling
see attached floor plan
Any assistance is gratefully accepted
ceiling height issues.pdf
This ceiling concept is popular here... I have created several models with both full vault and half vault living room ceilings. Because ceilings build over rooms, removing your room definition (invisible wall or room divider) makes for only one available ceiling height. Maybe the gurus here have a workaround...
Regards
