Hi
I have attached a floor plan showing 2 rooms
- one room has flat ceiling 10' in height
- second room has vaulted ceiling 24' height at center of ceiling
My issue is I have an invisible wall to separate the two rooms ,but when i remove remove the invisible wall section my vaulted ceiling turns to a flat ceiling
see attached floor plan
Any assistance is gratefully accepted
ceiling height issues.pdf
This ceiling concept is popular here... I have created several models with both full vault and half vault living room ceilings. Because ceilings build over rooms, removing your room definition (invisible wall or room divider) makes for only one available ceiling height. Maybe the gurus here have a workaround...
Regards
If you want a single room, you can remove the ceiling, then manually place a flat ceiling plane in the "flat" room, and sloped ceiling planes in the "vault" room.
    28415
    HeartAlba
    HeartAlba
