robdyck Posted July 31, 2020 Share Posted July 31, 2020 I use a spreadsheet to perform certain calculations, then I copy the cells and paste into Chief. When I do this, it imports cell borders, but I'm not sure if the line weight of these borders can be controlled. They are much heavier than I typically use. Does anyone know if this can be controlled? Link to comment Share on other sites More sharing options...
Alaskan_Son Posted July 31, 2020 Share Posted July 31, 2020 19 minutes ago, robdyck said: I use a spreadsheet to perform certain calculations, then I copy the cells and paste into Chief. When I do this, it imports cell borders, but I'm not sure if the line weight of these borders can be controlled. They are much heavier than I typically use. Does anyone know if this can be controlled? 2 best options I can think of... 1. Paste without the borders into Rich Text Box and add your own afterward. 2. Better yet, paste into a standard text box and Display Grid Lines. You can then simply reuse the Text Box and/or manually created grids for future plans. 1 Link to comment Share on other sites More sharing options...
robdyck Posted July 31, 2020 Author Share Posted July 31, 2020 14 minutes ago, Alaskan_Son said: Better yet, paste into a standard text box and Display Grid Lines. Thanks Michael. Not sure why I didn't think of that! That provide the line weight control I asked for. And 2 separate text boxes will provide the appropriate text alignment: Link to comment Share on other sites More sharing options...
