Hammer7
correcting framing
Can I delete my framing and change the defaults and then rebuild framing to match existing conditions.  This renovation has an existing floor with lapped 2x8s over a tripled lumber beam in center, typ.
It's the "deleting" part that I am looking for now.
My display shows a wrench and that it is used but I'm not finding info on adding it in.  I changed the beam setting to 10"x4 1/2" but not finding the handle on how to do that just yet....
With auto flooring on, go to the framing tools and look for the FLOOR/CEILING BEAM tool. Select that tool and drag your beam under the floor. The floor framing will adjust if you have it set correctly. Auto framing will not auto place beams, you have to place those manually.
    28425
    ChiefProBrian
    ChiefProBrian
