mtldesigns Posted July 29, 2020 Share Posted July 29, 2020 Trying to figure out the best method here. Originally I had the B&B and corrugated as a pony the complete length of the front of this 36' long future spec home. Now the broker wants the entry to be all corrugated. At first I just broke the wall at the white vertical ledger board and made the wall 100% corrugated. Now that I am to the point of doing framing wall details, I have two separate wall pieces. Would the best way to accomplish this is to create a new wall type, with no exterior finish, then just do two material regions? How does that show up on material reports? This broker is all about those reports. Thx in advance. Link to comment Share on other sites More sharing options...
mtldesigns Posted July 29, 2020 Author Share Posted July 29, 2020 A one piece wall detail, at 36' long. Whats shown are two different wall types (one of course being a pony) Link to comment Share on other sites More sharing options...
Chopsaw Posted July 29, 2020 Share Posted July 29, 2020 Looks to me like you could get away with just the corrugated wall type and the B&B Material Regions. But if you already have the B&B defined as a wall type maybe just frame manually beyond the pony wall so it will appear all in one detail. Always lots of options in Chief. You just have to try one and see how it works. Link to comment Share on other sites More sharing options...
mtldesigns Posted July 29, 2020 Author Share Posted July 29, 2020 I don't know what I was scared for. Worked as planned. I made the whole length of the wall a new wall def without a exterior finish, and just material region the corrugated and B&B. The wall detail is one 36' long section now... Nvr played with MR on walls before.. learn something new everyday. Link to comment Share on other sites More sharing options...
Chopsaw Posted July 29, 2020 Share Posted July 29, 2020 Material regions will also cut the existing finish so you can limit the use of the material regions and keep them to a minimum. Link to comment Share on other sites More sharing options...
