GeneDavis Posted July 25, 2020 Share Posted July 25, 2020 Where the basement slab has bearing loads, posts or walls, we thicken the slab appropriately, and typically use CAD and text on the foundation plan to show where and what. It can be modeled in 3D by making and placing slabs and or solids where needed. What do you do if you want it all included in the concrete count in the material list? I'd like NOT to do walls with footings and posts with footings. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted July 25, 2020 Share Posted July 25, 2020 3 minutes ago, solver said: Use the Slab Footing tool? Yes. This^^^^ Link to comment Share on other sites More sharing options...
GeneDavis Posted July 25, 2020 Author Share Posted July 25, 2020 Which is where, please? Link to comment Share on other sites More sharing options...
Alaskan_Son Posted July 25, 2020 Share Posted July 25, 2020 1 minute ago, GeneDavis said: Which is where, please? It's in your wall tools. You just need to specify the Pour Number in it's Foundation tab to match the Pour Number for the slab in which you're using it. Link to comment Share on other sites More sharing options...
GeneDavis Posted July 25, 2020 Author Share Posted July 25, 2020 I know that tool and can use it, but wish it had more options. If I've a 4" wall with a 16" pad under, I want it to go another 4", which requires a short invisible wall. i just wish Chief would add an option to the slabs and solids spec that would let the volumes tally in the concrete foundation counts. I'll make a suggestion in that subforum. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted July 25, 2020 Share Posted July 25, 2020 2 minutes ago, GeneDavis said: I know that tool and can use it, but wish it had more options. If I've a 4" wall with a 16" pad under, I want it to go another 4", which requires a short invisible wall. You place them on the foundation layer completely independent of the walls above. No need for any invisible walls. 3 minutes ago, GeneDavis said: i just wish Chief would add an option to the slabs and solids spec that would let the volumes tally in the concrete foundation counts. Read up on using Material Definitions and the Components capabilities. Link to comment Share on other sites More sharing options...
GeneDavis Posted July 25, 2020 Author Share Posted July 25, 2020 That's better. Thanks. I can use the 4" slabs placed under the 4" floor slab, ID'd as FOUNDATION in the Components dialog. Itemized nicely in the material list, and easier and more flexible than using walls, for this particular plan. Link to comment Share on other sites More sharing options...
