How To Show An Elevator Cab In 3D
agenoarch
Commonly I just make a series of "open Below" rooms that line up, floor to floor. On each floor I place a sliding door with appropriate trim. This serves fine in plan views.
If you require a cross section then you can carefully add the cab as 2D CAD overlays on the cross section. I have never been asked to model an elevatior with the doors open and I suppose the quality of rendering would dictate how much detai needed to be added as poly-line solids, molding poly-lines etc. One can get quite fancy and detailed at need.
