mariannekbauer Posted July 15, 2020 Share Posted July 15, 2020 I am trying to create the band of windows under a slanted roof on a midcentury modern building. The windows are going on all four walls, and the roof will sit on top of them. I cannot get the windows close enough together to avoid wall sections showing. I also cannot figure out how to make the windows meet in the corners. I have attached images showing the type of design I am looking for (note that I am not opposed to see a metal frame around each window section.) Any help is greatly appreciated! Link to comment Share on other sites More sharing options...
mtldesigns Posted July 15, 2020 Share Posted July 15, 2020 Maybe a pony wall with a glass wall on the upper? (like a shower) I don't know if roof would cut that off though. 1 Link to comment Share on other sites More sharing options...
Chopsaw Posted July 15, 2020 Share Posted July 15, 2020 32 minutes ago, mtldesigns said: I don't know if roof would cut that off though. Yes it will. You could do it just like that and manually add the supports or even do it automatically as a panel railing wall. 1 Link to comment Share on other sites More sharing options...
