Treehouse2339 Posted July 9, 2020 Share Posted July 9, 2020 I am doing a livable barn and want to just show studs and no drywall. I put in barn doors and that worked fine as you can see but when I install windows the framing will not cut and no header. Link to comment Share on other sites More sharing options...
Chopsaw Posted July 9, 2020 Share Posted July 9, 2020 Did you frame and then install the windows ? If so you need to re-frame. Unless you have "Automatically Build Wall Framing" turned on ? 1 Link to comment Share on other sites More sharing options...
