Lines That Show Cabinet Sides Missing.
4hotshoez
Go to solution Solved by dshall,
  • Solution
The lines have been missing for some time and I do not know how to get them back. I have checked layers and defaults, but I am not seeing it. Anyone?
oooh,  oooh,  let me handle this.....  why you knucklehead,  that is the way you probably want it to show,  but just in case,
DEFAULT SETTINGS<CABINETS<GENERAL CABINET< UNCHECK PARTIAL MODULE LINES
easy peasy,  but I bet that if your try it,  you will probably prefer the PARTIAL MODULE LINES.
Thank you,  thank you very mucho.
Cabinet module lines I believe. Easiest way to find stuff like that is to select one of the cabinets, click the object layer properties tool, and check all the layers associated with that item.
Nope,  that won't do it Michael.....  note the capital letter.
