TotalStation Posted June 28, 2020 Share Posted June 28, 2020 Hello, I have been working on a plan file for awhile now and suddenly it takes forever to change doors,trim or any other task that i want to do," Its Slow". i thought it would be my system i am using but i changed to other plan files of the same size that i am working on and its speed is just fine, May i have done something in this plan files settings? Any advice?? CA X12 Link to comment Share on other sites More sharing options...
Michael_Gia Posted June 28, 2020 Share Posted June 28, 2020 Do you have framing on? Or a large PDF that you’ve imported? Link to comment Share on other sites More sharing options...
Chopsaw Posted June 28, 2020 Share Posted June 28, 2020 If it happened suddenly, what were you doing just before it happened ? It is not necessarily the size of the file that dictates the efficiency that it runs. Content is critical. Do you have imported cad or imported symbols ? Did you build a custom item ? What is the "system" you are using ? Upload the plan file if you want to know if it is slow on a different system. Is it slow in 3D or in plan view ? Link to comment Share on other sites More sharing options...
TotalStation Posted June 28, 2020 Author Share Posted June 28, 2020 Fellow Canadians, Thanks for the quick response,I have it sorted out i am thinking, it was the framing. As to your question Chopsaw, it was slow in 3D and planview. P.B CA X12 Link to comment Share on other sites More sharing options...
